Hi Jason;
If the filter is OK, it's large enough for your pool.
I'd recommend the following steps:
1. Physically clean the pool as much as you can -- leaf net + vacuum attached to small rented trash pump. (Do NOT pump the water below the safe level -- leave at least 6" of water on the HIGHEST horizontal surface in your pool (shallow end floor, or possibly, suntan ledge or steps.)
2. Get a cheap local OTO/phenol red drops kit (or an HTH 6-way drops kit, if available). Test the water. The main issue for now is whether the pH is between 7 and 8. If it's not, post your readings here.
3. Once you've got the bulk leaves and trash removed from the pool, begin adding bleach in the evenings, 5 gallons of PLAIN 8% household bleach per dose. Dilute the bleach in a bucket with water, and pour around the pool. BRUSH the pool after adding the bleach, both to break up the algae, and to mix the bleach.
4. Once the pool's color has gone to grayish or light brown, with no green, cut your doses back to 2 gallons per evening. Skip doses if the OTO level is ORANGE or orange-tinted.
5. Once pool is somewhat cleaned, make sure you can repair the liner. You need to rule out the need for a liner replacement. See http://pool9.net/liner-patch/
6. Also, inspect your filter. A new filter of that size is over $500. If you WANT to replace it, that's fine, but if you have to spend $2,000 on a liner, you may want to save elsewhere.
7. Once you have inspected your pool, complete the pool info form: http://pool9.net/pf-pool-chart .
Let me know how it goes.
