Results 1 to 10 of 26
Thread: Water testing and left over trichlo
    Default Re: Water testing and left over trichlo
    There should not be any chlorine odor at 15 ppm UNLESS there's something in the water to still oxidize. As we speak, I have a heavily used 200,000 gallon local country club pool at 15 - 20 ppm FC . . . and the water is completely odorless.
    Jun 2014
    Bakersfield, CA
    Fair enough, I will continue to monitor.
    Sean
    15k gal concrete freeform IG pool, Sta-Rite PLM200 cartridge filter, Sta-Rite 3/4HP P6E6D-205L pump, feeding trichlor, 8hrs/day. PF=8
    Jun 2014
    Bakersfield, CA
    So, we did some make shift aeration this weekend. Seems as it had a small effect.
    Added 2 jugs of bleach after this test was taken.
    Sean
    ok. keep us posted.
    Jun 2014
    Bakersfield, CA
    Posted new test results.
    Added 1/2 gallon muriatic acid to reduce pH levels. According to this post http://www.poolsolutions.com/gd/lowe...p-by-step.html
    I am going to lower to 6.8 as this is the lowest my tester will go, I will then begin the aeration to lower the TA.
    How long should I wait before the next dose of acid to lower pH?
    Sean
    The aeration raises the pH, not lowers the TA. Don't drop the pH to 6.8 on your kit because by doing so, you don't know if 6.8 means 6.8 or any value lower. Lower it to 6.9 or 7.0 instead. You add the next dose of acid when your pH is raised back up to 7.6 or so.
    Jun 2014
    Bakersfield, CA
    New results posted, seeing nice results in TA and CYA.
    Will continue aeration and add a small amount (1/4 gallon) of acid to lower pH.
    Sean
  1. water testing
    By Neenie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-01-2014, 03:41 PM
  2. Help... intex pool left uncovered with some water over winter!!!
    By Mud&makeupchevygirl13 in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-22-2014, 07:23 PM
  3. I left the guy at Leslie's pool speechless with my water test results...
    By ramoniqque in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-02-2011, 11:26 PM
  4. testing tap water
    By sunofthebeach in forum General Interest
    Last Post: 08-25-2008, 02:18 AM
