Results 1 to 10 of 26
Thread: Water testing and left over trichlo
    Jun 2014
    Bakersfield, CA
    Default Re: Water testing and left over trichlo
    [QUOTE=PoolDoc;120742]Post your results here:
    http://pool9.net/pf-hist-chart/
    I must not know what I am doing as I am unable to type or edit this document
    And your pool info, here:
    http://pool9.net/pf-pool-form/
    Done
    Sean
    15k gal concrete freeform IG pool, Sta-Rite PLM200 cartridge filter, Sta-Rite 3/4HP P6E6D-205L pump, feeding trichlor, 8hrs/day. PF=8
    My bad: http://pool9.net/pf-hist-form/ . I need to come up with better links, because those confuse me!
    I recalc-ed your pool volume, after looking at your submitted dimensions, and Google maps (since you submitted your address -- which only I can see). I posted 15K gallons, but because of the free form indents, it's actually probably less. That puts you in the norm: way more than 50% of pool owners have significantly incorrect figures for their volumes, and more than 3/4 of the errors or on the high side. Since such errors sell more chems, pools stores have NO incentive to correct them.
    Anyhow, on your pool, with a PF of 8, a pound of trichlor (90% avail. cl.) will add ~ 7 ppm (8 x 0.9). A gallon of PLAIN 8% househould bleach (~0.7 lbs Cl2 equiv) will add about 6 ppm (8 x 0.7).
    Did you retest your CYA?
    Jun 2014
    Bakersfield, CA
    Performed the CYA test, black dot disappeared at 85.
    Chlorine is 1 and Ph is 7.5
    Sean
    So, if you diluted as Ben suggested above, then you need to multiply the reading of 85 x3 = 255.
    If it were my pool and I was able, I'd probably drain and refill a good bit of that water since you have a ridiculously high CYA. But, where you live there may be water restrictions. Wait and see what Ben's recommendation is for you.
    But, get some bleach in there. A chlorine of 1 is an open invitation to algae. I'd probably put about 4 of the 121-oz jugs of bleach in there.
    Jun 2014
    Bakersfield, CA
    I just entered my new test results. I dumped 4 jugs of bleach last night. I going to put in 4 more tonight. I have a cartridge filter, is it ok to be putting bleach directly in filter basket area or spread around pool? Seems as though I also need a feeder, any recommendations?
    Sean
    I think the cartridge will be find, but if you like, just put one in the skimmer and the rest in the pool.
    You need to continue with the 4 bottle doses daily, till you can hold chlorine overnight. After that, you'll need to achieved 15 - 20 ppm levels, in order to keep your pool algae free, given the CYA=250 level that you reported.
    Jun 2014
    Bakersfield, CA
    New test!
    It appears the chlorine is staying in better but pH is down and TA is up. Both CH and CYA are down slightly.
    I will continue the 4 jugs regimen tonight. As for pH, it took 6 drops to bring the color to 7.5ppm. Should be adjusted before or after adding bleach to pool. Day or night?
    Sean
  1. water testing
    By Neenie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-01-2014, 04:41 PM
  2. Help... intex pool left uncovered with some water over winter!!!
    By Mud&makeupchevygirl13 in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-22-2014, 08:23 PM
  3. I left the guy at Leslie's pool speechless with my water test results...
    By ramoniqque in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-03-2011, 12:26 AM
  4. testing tap water
    By sunofthebeach in forum General Interest
    Last Post: 08-25-2008, 03:18 AM
