Results 1 to 5 of 5
Thread: Newby
    Jun 2014
    Default Newby
    I have a 24' above ground pool that is breaking the bank with chemicals. I was wondering how the bbb method works. Thanks in advance for any info!!!!
    Default Re: Newby
    BBB is all about learning to take care of your pool by testing frequently and adding only what you need. In many cases, there are grocery store products that you can use instead of expensive pool store chemicals. I would suggest that you do a lot of reading here on the forum, especially the stickied threads at the top of a lot of the subsections. Also, read over on our sister website www.poolsolutions.com.
    Then, come back if you have specific questions that you need help with.
    Welcome to the Pool Forum!
    (By the way, until your registration is completed, you will have to log out first to be able to see the rest of the forum.)
    Pappy is offline PF Supporter Widget Weaver Pappy 0
    May 2014
    Plano, TX
    Default Re: Newby
    Our 15' Intex went from a green money sucker last year to a sparkling clear, easy to maintain pleasure this year. Once I got the pH up with 20 Mule Team Borax, and the Cyanuric acid level where it needs to be, bleach is the only thing that gets added on a regular basis. I VERY HIGHLY recommend the BBB method.
    Intex 15ftx4ft 4500 gal. 3/4 HP Pentair WhisperFlo pump. Hayward 21" sand filter. Taylor K-2006 & K-1106 kits. PF=27
    Virginia
    Default Re: Newby
    Quote Originally Posted by Pappy View Post
    +1
    Learning how to properly test and maintain a pool from knowledge gained here is the best thing an owner can do.
    22'x40' Grecian Lazy L 20K gal IG vinyl pool; Aqua Rite SWCG T15 cell; Hayward Pro Grid 6020 DE filter; Hayward Superpump 1hp pump; 12 hrs; Taylor K-2006; city; PF:6
  1. Newby
    By PattiBomgaars in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-21-2012, 04:28 PM
  2. 2 questions from a newby
    By sgband in forum Pool Equipment & Operations
    Last Post: 01-29-2012, 05:51 PM
  3. Need help with chlorine. I'm a newby
    By stormbean in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2011, 04:50 PM
  4. One day soon.. you will not be a newby too!
    By chuck9997 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2010, 09:23 PM
  5. Newby with problems, times 2.
    By theboogins in forum Pool Equipment & Operations
    Last Post: 04-16-2006, 11:43 PM
