Thread: SWG Pentair Intellichlor not producing chlorine
    Jun 2014
    Utah
    Default SWG Pentair Intellichlor not producing chlorine
    We are new to this, ( our pool is a year old) and are having troubles with our SWG already. We have cleaned it as recommended and have ran it a full 24 hours to try to get our chlorine level up. We've treated the pool with the "start up" kit to open it this Spring, therefore adding almost 8lbs of shock already. At what point do we assume the SWG is defective and call Pentair?
    Default Re: SWG Pentair Intellichlor not producing chlorine
    I'd don't know whether it is defective or not but if it were mine, I'd go ahead and call Pentair anyways. Nobody will know their product better than someone who works for the company. Hope you get a solution.
    Welcome to the Pool Forum!
    When to call? Assuming that all the indications are normal, after you have
    1. Tested and adjusted your water to the proper limits. You need a K2006 and accurate salt strips.
    http://pool9.net/tk/
    2. Made sure your temperature is above 70 degrees.
    Here's the manual
    http://www.pentairpool.com/pdfs/Inte...tor520589J.pdf
    membership upgraded.
    I should add -- if you have ammonia in your pool, as a result of biodegradation of stabilizer over the winter, it may be working fine even though you can't see any effects.
    Testkits!
    Jun 2014
    Utah
    Unhappy Re: SWG Pentair Intellichlor not producing chlorine
    Thank you, PoolDoc and Watermom. Still nothing. We've had the water tested at our local pool store and the free chlorine is .26, total chlorine .26 and combined chlorine= 0. We've got slimy floor and walls. The salt is 3400 ppm, right where it should be for the unit to be producing chlorine. Now... this is when I assume the SWG is defective.
    One more recommendation, then.
    + Use plain 8% store brand bleach to bring your chlorine up to normal levels, and to maintain them for several days. THEN, see if the SWCG can keep up.
  1. Pentair intellichlor upgrade
    By Smonahan0129 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2014, 05:17 PM
  2. Adjusting Pentair Intellichlor IC40
    By newpoolguy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2011, 11:22 PM
  3. Intellichlor by Pentair Cell Light not on and other issues
    By TAS17 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-02-2010, 02:45 AM
  4. Anyone familar with Pentair IntelliChlor?
    By mshumack in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2006, 02:59 PM
