Results 1 to 10 of 33
Thread: having possible mustard algae problem 3 weeks now
    Jun 2014
    Texas
    Default Re: having possible mustard algae problem 3 weeks now
    I am back home. I purchased Phosfree from Natural Chemistry and I purchased the Aqua Chek test kit that you listed. The Phosfree came with a test kit included.
    I tested the phosphate level with the both. The Natural Chemistry one shows over 1000 ppm for phosphates. The Aqua Chek one shows at least 300 ppm, maybe a little darker.
    The pool is crystal clear right now with powdery green algae in the wrinkled areas in the deep end. small spots of visible algae growth in the shadows of the shallow end.
    I am going to vacuum to waste and then see what you want to do.
    OTO drops show 5 ppm FC. I read the instructions the other day that high chlorine can affect the phosphate test results, so I told her not to add any yesterday.
    30k gal 20x40 vinyl IG pool, Hayward S244T, 2spd 1HP pump, time clock. PF=4
    Quote Originally Posted by bluebayou View Post
    Interesting.
    When I did the side-by-sides with the Taylor and the AquaCheck, I got similar readings below 1000 ppb with both. But above 1000, all the readings from the AquaCheck were the same. I'm some what confident of my results, since I started with tap water (about 3,000 ppb at that location) and did successive dilutions with distilled water. So, even if my starting value was off (not 3,000), I knew that each succeeding result should be 1/2 of the preceding one.
    I wouldn't suspect Natural Chemistry of deliberately creating a kit that overstates PO4, but I would suspect them of not caring much when someone pointed it out. After all, having a kit that shows their product as being more effective than it is would help them sell product.
    I'll be VERY interested, once you reach PO4<100 ppb, to see what the Natural Chemistry test shows.
    BTW, I've revised the phosphate link above. It took me several phone calls to Kem-Tek (KIK) to find out what's going on. Apparently, they are slowly closing out the Kem-Tek brand and replacing it with the Clorox brand -- but KIK is blending and packaging all the products. Their chief chemist told me the products themselves are completely unchanged.
    However, because Amazon has not yet distributed the Clorox products to all its warehouses, Amazon is showing the Clorox products as "temporarily unavailable" which apparently means "since we don't have the product in all locations, we don't want you to hold us to our normal shipping standards"!
    Jun 2014
    Texas
    on a side note, the pool filter was off since Thursday around noon apparently. I started the system on "filter" before vacuuming. One return was not functioning. After 10-15 seconds (about the time to realize it and to walk to the return) it started blowing green powder into the pool for 4-5 seconds and then clear water.
    otherwise, I am going to use the Phosfree. It says run filter for 48 hours and then to retest.
    Jun 2014
    Texas
    after adding 1.5L of Phosfree 48 hours ago, the AquaCheck test shows about 100 ppm (definitely a bluish tint, but not matching the 200 ppm color). the Natural Chemistry test still shows greater than 1000 ppm.
    yesterday, I checked on the pool at 11 am and at 3 pm. there was visibly more of the brownish powder in the shallow end.
    It accumulates in the same patterns every time. could it just be a particulate and not living algae? I don't understand where it is coming from if its dead algae. I really don't understand how it could double the visible amount in the course of 4 hours if it was growing.
    the powder isnt attached to the floor and it brushes away with movement, but there will be obvious green growth under the powder (sometimes).
    Saturday at 8 am there was very little material in the pool and the OTO test showed 10 ppm. Sunday at 3 pm the OTO test was maybe 4 ppm.
    I am thinking about increasing my regular FC amount to 6 ppm. previous years I have just been around 3 ppm, but the CYA from test strips was less than 30. 10 ppm seems to be the breaking point for algae growth (not the brown powder, but greenish tint to the water and green algae on the sides and ladder).
    1. Order the Taylor kit; using successive dilutions with distilled water, I validated it against the AquaCheck kit, and they correlated well at the lower levels. I'm guessing the Natural Chemistry kit is bogus. Remember, they'll sell more if it consistently reads high! http://pool9.net/tk/.
    Tip: get some sticky putty (Scotch brand @ Walmart) to hold the Taylor test cylinder. It's really tall and easy to tip over. A bit of sticky putty to set it on will make the test go much more smoothly. And use a TIMER for the wait period -- otherwise it's too easy to get impatient.
    Regarding the powder - I haven't re-read the whole thread: did we ever suggest, or did you ever do the DE test? It would confirm or eliminate the filter as a source of problems. Plus, if you hand vacuumed the powder while DE was in the filter, you could be sure of capturing the dirt. And, if there is live algae in the pool, it will tend to rapidly stop up the DE and thus your filter, giving another indication. http://pool9.net/de-test/
    Jun 2014
    Texas
    you had me to do the DE test and none came out the returns.
    Sunday afternoon I added 3 pounds of 53% cal hypo and 3 cal hypo tablets to the skimmers.
    Monday the FC was 10 ppm.
    I intentionally did not do anything the pool yesterday. As of right now, 24 hours later, the FC is 5 ppm.
    I have new growth on the shady sides and in the deep end. The brown powder is accumulated on the pool floor, but does not have new growth under it.
    I think that the powder is dead algae being returned into the pool.
    My question is: where is the LIVE algae? if there was active growth some place in the plumbing or filter then would that explain it? I would figure that algae needed sunlight. We do not have lights in the pool. The skimmers could use a cleaning, but no algae visible there.
    If I had to estimate then I would say there is one square foot of visible green algae growth TOTAL in the pool right now. But, I have maybe 5-6 square feet of the brown powder at a time.
    Would the drop from 10 ppm on Monday to 5 ppm today be normal? Seems too fast to lose that much chlorine with CYA at 75
    When mustard algae is breeding, you will lose chlorine faster than normal.
    1. Operate your filter 24/7.
    2. Keep your chlorine in the ORANGE to orange-tinted DARK YELLOW range.
    3. Add 2 - 3 cups of DE powder after EACH backwash. That will stop algae from leaking through.
    4. Brush the algae spots after each chlorine boost.
    Where did you get 53% cal hypo? What *else* is in it? What's the brand/product name?
  1. Dealing w/Algae for 3 weeks
    By TheKs in forum Dealing with Algae & Slime
    Last Post: 08-24-2012, 05:49 PM
  2. Problem with mustard algae
    By NREAGAN in forum Dealing with Algae & Slime
    Last Post: 06-30-2012, 09:06 AM
  3. Mustard Algae problem or not?
    By keastman in forum Dealing with Algae & Slime
    Last Post: 05-18-2012, 10:01 PM
  4. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 08:40 PM
  5. Green algae? Mustard algae?
    Last Post: 07-15-2007, 08:32 PM
