New information, I replaced the tri-sensor and the cell but now have a different message.
I went with the RC-52 (SC-60) which is the largest my unit will accept. Purchased from saltpoolguys.com.
The tri-sensor was bad and the new one is reporting a temp of 82 degrees which is what the thermometer in the pool is reading.
Salt is reported at 3300ppm which is what the old sensor reported and the same as the pool store measured.
I set the control unit back to power level 1 and changed the cell type to SC-60.
I still have a flashing red light on the control unit and the message now reads "Warning check/clean cell?"
The cell is clean and i dont see anything on any of the blades, all 15 are the same length, Some appear to be newer than others so not sure if the cell may be bad?
when testing the unit I have 17 volts and 2.9 Amps reported on the display.
When i turn the unit on initially, once it runs throught its tests, the purifier states 60% but within about 5 seconds that changes to 48%.
The unit is on and states purifier on 48%
Any thoughts on what could be causing the check/clean cell message?
