Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Pool Pilot Digital 220 unit - Warning Low Amps - Cell? and Bad Temp Sense
FAQ
register
Results 1 to 10 of 21
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-02-2014
08:44 AM
#8
rcenturion
View Profile
View Forum Posts
Registered+
May 2012
Miami, FL
Re: Pool Pilot Digital 220 unit - Warning Low Amps - Cell? and Bad Temp Sense
my Autopilot cells have lasted around 4-5 years. I use the SC-36
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
I Installed My Pool Pilot Today!
traditional salt chemical system or go with the Mineral Springs salt system?
Digital Pool Pilot Low Amps Reading Solved (Hint - No New Cell Needed)
By ghanner in forum Salt Generators (SWCG) & other Chlorine Feeders
1
Last Post:
05-25-2014,
01:59 PM
Pool Pilot Digital. Low Amps check cell?
By Bobdog in forum Salt Generators (SWCG) & other Chlorine Feeders
2
Last Post:
05-08-2014,
12:44 PM
Pool Pilot Low Amps Cell 0V 0.6A
By vgg659 in forum Salt Generators (SWCG) & other Chlorine Feeders
7
Last Post:
05-22-2011,
02:07 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
