Re: Green Pool (Was black at first)
My CYA reading of the other day might have been a user error (you can put in the tube two ways and the wrong way is blocking the colorimeter "view")
Anyways. Pool water is a teal green. Only able to see the bottom at the shallow end.
My 6/5 8:30am numbers:
FC 1.33
PH 7.0
ALY 184
CH 172
CYA 8
I am sure that I am bleaching out. I tried the over 10PPM FC procedure but those numbers where very strange and I had lack of time for a redo. Have to make money to buy more Pool chemicals
K2006 kit should arrive tomorrow.
One observation my robotic pool cleaner is floating on the surface and doesn't want to "sink" to the bottom of the pool. The clean out of the cleaner showed some regular "waste and some worms" it wasn't clogged anymore with dead algae.
30k gal IG vinyl pool, Hayward S200 filter, Pentair 2HP SuperFlo, 24hr ops. PF=4
