Thread: Pool cleaning eqpt
    May 2014
    Southwest Desert
    Default Pool cleaning eqpt
    First-time user. Building a lap pool next month in the Southern Cali desert: 48 ft feet long, 5 ft deep 7.5 ft wide. Skimmer on both ends. Two vac inlets for cleaning to be installed (not located yet). How does one clean the pool being so long? Had a G3 Barracuda in last pool (30x15) and worked very well, but I suspect this will be a different issue, that is why I am placing two inlets. Will I need 2 cleaning systems - suction systems or electrical, need advice.
    Also, read the thread on UV, and have decided to not install system. Thanks. Chico 1412
    Default Re: Pool cleaning eqpt
    Talk to Polaris customer support; their pressure side cleaners *might* be able to do it, and it would certainly be simpler with one cleaner, than with two.
    If you find out that two are needed, you may want to set up a timer that can switch the booster pump ON/OFF (timer core #1) and operate a powered Jandy valve (timer core #2) to SWITCH between cleaners. I can just imagine the tangles, if you let them both run at the same time!
    . . . membership updated.
    May 2014
    Southwest Desert
    Thanks for the advice PoolDoc. I was hoping that since there are several lap pools out there that someone would have a definitive answer. I have two Hayward Variable pumps and would make the hoses only reach midway in the pool to avoid potential tangling but I thought that in this day and age there would be a more practical solution.
    What you are describing is a very, very small market. The only sort of enterprise that might target that would be garage-shop level.
  1. Help cleaning up a pool, after algae
    By rourke in forum Dealing with Algae & Slime
    Last Post: 06-05-2012, 02:01 PM
  2. cleaning the snow around pool
    By ArtCan in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 01-17-2012, 09:02 PM
  3. Basic Pool Cleaning -- What do I do?
    By subedoo in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-02-2006, 01:33 AM
  4. Cleaning the tiles around the rim of the pool?
    By bortoldr in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-20-2006, 09:40 AM
