Do you know of any solution to repair the wall that has started to rust from the inside? They replaced one half last year because of rust and I thought maybe I could pull the liner down sand off the rust and primer the area. Then slide in some galvanized siding to support the area. I can't figure out why it's rusting. Also could this be covered by the warranty? Any help would be appreciated.
