Thread: Need advice on replacing sandfilter
    May 2014
    Illinois
    Default Need advice on replacing sandfilter
    Have a Tagelus TA 60 on my pool now , tank cracked over winter. Want to stay away from hayward top valves, is there a good top mount valve brand that doesnt leak?
    Default Re: Need advice on replacing sandfilter
    I haven't seen any evidence that any of the other top-mount multiport valves are better than Haywards, but both Pentair and Jandy (Zodiac) make their own, even if it's pretty much a copy of Haywards.
    Personally, I'd try to avoid top-mount filters as much as possible; they are a PAIN to work on, compared to side mount filters.
    . . . membership upgraded
    May 2014
    Illinois
    I did end up getting a Pentair Sandollar sd70.It had the same diameter of my Tagelus ta60, though slightly less sand. Best I could do on a Memorial day weekend.I'm having some issues trying to vacum. If I plug one skimmer, it looks like I can't get enough flow to keep the pump primed fully. Had to only partially plug one one skimmer.
  1. Replacing Sand Filter - need advice
    By maggie2712 in forum Pool Equipment & Operations
    Last Post: 04-02-2014, 11:30 AM
  2. Advice for replacing tile at waterline
    By floridagator in forum In-Ground Pool Construction and Repair
    Last Post: 03-06-2014, 03:20 PM
  3. Replacing liner; Advice needed!
    By JenniferB in forum In-Ground Pool Construction and Repair
    Last Post: 01-10-2007, 05:38 PM
  4. Replacing IG Liner -- Need lots of advice
    By rak70 in forum In-Ground Pool Construction and Repair
    Last Post: 07-12-2006, 11:01 AM
