Results 11 to 20 of 23
Thread: Leveling the ground for a new Intex pool
Threaded View
  1. #5
    May 2014
    Plano, TX
    Default Re: Leveling the ground for a new Intex pool
    If you have not already done so, read this. Your life will be easier and your pool will be happier.
    http://pool9.net/ssr/
    http://pool9.net/ag-pool-problems/
    If you have the cartridge filter, order GOOD cartridges now, the warning about the Intex cartridges is HUGELY understated. The test kit info is also very IMPORTANT!!!
    If you have a sand filter, you might be interested in this,
    http://www.walmart.com/ip/20434370
    the picture is WRONG, the description is CORRECT. Many of the local Walmarts (Dallas TX area) have it in stock. I have an Intex 14" sand filter and about 1/8 cup seems to work great.
    This is WHY you might be interested in D.E.
    http://pool9.net/de-test/
    Enjoy your new pool!
  1. Leveling Above Ground Pool (ABG)
    By sjeffers01 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-25-2014, 04:40 PM
  2. Starting from scratch - leveling ground
    By tebbert in forum Above-Ground Pool Construction & Repair
    Last Post: 08-07-2012, 10:40 PM
  3. Doing some home work on Intex Ultra Frame - Leveling the ground
    By nazran in forum Intex-type Pool Setup & Operations
    Last Post: 07-28-2012, 11:37 PM
  4. leveling ground for pool
    By milo taliaferro in forum Above-Ground Pool Construction & Repair
    Last Post: 06-29-2011, 11:49 AM
  5. leveling and heating intex pool
    By savannah in forum Above-Ground Pool Construction & Repair
    Last Post: 04-11-2006, 11:06 AM
