Results 1 to 10 of 10
Thread: Need advice regarding cartridge filter...
    Default Re: Need advice regarding cartridge filter...
    From PacFab engineering bulletins I received in the early 90's:
    When I was running flows over 60 GPM, I always switched to the PacFab Full Flo valve, now called the "High Flow Valve":
    http://www.pentairpool.com/products/...w-valve-68.htm
    Over a 100 GPM, I made backwash valve chains, using an H-ladder and 4 full port ball valves.
    It's also worth noting that neither sand nor DE filters have a failure mode that approximates cartridge pleat collapse, illustrated on a System3 cartridge:
    (This cartridge also shows the effects of cleaning with a low power electric pressure washer. The pleat collapse results from high pressure drop across the cartridge that results when the filter clogs with algae or dirt. The 'fuzzy' fibers are a result of the pressure washing.)
    Once that failure mode has been achieved -- and I've seen it on EVERY modern "high capacity" cartridge that's been used even briefly on dirty pool water -- the cartridge cannot be restored, and pressure drops are far greater than with the new, un-collapsed, cartridge.
    mas985's Avatar
    Pleasanton, CA
    The cartridges I was quoting were the Hayward SwimClear and the Pentair Clean & Clear plus. You can see the curves here:
    http://www.hayward-pool.com/pdf/manu...xx25-C7000.pdf
    http://www.pentairpool.com/pdfs/CleanandClearOM.pdf
    But this cartridge has even lower head loss:
    http://www.pentairpool.com/pdfs/cleanclearrpOM.pdf
    But you are right, there are some lines that are worse. I would never recommend those since they are usually pretty small.
    As for cleaning a cartridge, I would never use a pressure washer. I use a small nozzle on the end of the hose which doesn't damage the fabric. That is probably one of the reasons why my cartridges have lasted so long (> 8 years).
    Mark
    I think it's pretty clear that there are some serious weaknesses in specific models of filters within each filter group . . . and that information about these problems is hard for new pool buyers to acquire. It's something I'd like to work on, hopefully with your help.
    Sorting out the whole problem with configuring and servicing electronic controls is out of my reach, at least for now. But I think we could do something useful with filters and pumps, that would help people make better decisions, and have better experiences with their pools.
  1. Sand filter vs cartridge type filter
    By stevens23 in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 06:54 AM
  2. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 05:05 PM
  3. cartridge filter with swg
    By cofa in forum Pool Equipment & Operations
    Last Post: 10-05-2008, 12:24 AM
  4. DE in a cartridge filter?
    By waterbear in forum Pool Equipment & Operations
    Last Post: 03-22-2007, 11:05 AM
  5. Filter Bag v. Cartridge
    By jimwnola in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-15-2006, 01:17 PM
