Re: Help! My 6-year old is dying to swim and I've gotGreen water even with high FC le
I just emailed all the pics PoolDoc requested on the wine glass testing and also pics of the green gunk still in my hoses and pool water. Again, it was very difficult to get a large enough sample of the green goo, as pooldoc calls it. I had already brushed and sprayed off at least 90% of it. Originally it was a light green flaky substance about like extremely large flakes of dandruff, but green. The sample I was able to obtain had a more grainy consistency like sawdust.
I tested again this afternoon while waiting on the wine glass testing. Results are as follows:
FC = 9.5 ppm
CC = 0
PH = 7.2 (I added a little more Borax to hopefully boost a little more)
TA = 80 ppm
CH = 30 ppm
CYA = approximately 35 ppm
CH tests started working correctly on 6/1/14. The modified CH tests started out Blue instead of Red. Every time I have ever tried to complete this test before 6/1, the samples started out blue so I have never been able to take a good test on it.
What now? As you will see from the pics, the pool is actually getting "less green" by letting the chlorine drop for some reason. My filter cartridge has been catching large of amounts the last couple of days once the FC and PH dropped. Any guesses why?
South Carolina - Intex Ultra 16' x 48" (5,061 gallons), Intex Krystal Clear SWCG, Using Taylor K-2006 kit
