Re: Help! My 6-year old is dying to swim and I've gotGreen water even with high FC le
OK, I've got several stupid questions....Please excuse my ignorance. I plan to try and find some dichlor locally tonight or tomorrow morning.
1. Pooldoc stated not to use Trichlo. I know it is not the same as dichlor, hence the name, but I thought both were acceptable means to add FC and CYA, as long as you need CYA. I actually bought a floater and some tabs with 99.0%-Trichloro-s-triazinetrione & 1%other ingredients with 90% available chlorine last weekend. I have not used any of it yet thank goodness and can hopefully return it. I was planning to use it to boost my CYA after getting the green knocked out of my water. My question is...What is the difference in dichlor and trichlor?
2. If it is copper, is there something that will make it drop out so I can vacuum it or dissolve back into the water so it is not visible?
3. Why would copper just show up this year since it is the original pool water from 3 years ago? I have never drained the pool. I have added water over time though. Would algae make it all of a sudden appear? Or the SWCG? I have used the SWCG in all of the 3 previous seasons and had clear water last fall when closing the pool.
4. I have powdered cyanuric acid stabilizer on hand too. Can I use it to raise the CYA until I get the dichlor or will it just get filtered out?
Reason: reformat for clarity
South Carolina - Intex Ultra 16' x 48" (5,061 gallons), Intex Krystal Clear SWCG, Using Taylor K-2006 kit
