Thread: Milky water
    May 2014
    Mass
    Default Milky water
    Hi,
    I opened the pool about a week ago and have been filtering but the water will not clear up. It is cloudy/milky color and I can barely see the second step.
    I just bought a K-2006 test kit and here are my readings:
    FC 1 (I think this was much higher but has been dropping)
    CC 4
    Ph 7.6
    CYA 0
    TA 150
    I just added about 2lbs or CYA today. Do you think this could be the cause of the milky water or could it be something else?
    Default Re: Milky water
    Could be many things.
    1. Tell us what kind/size of pool you have and the make/model of your pump and filter.
    2. Buy a cheap OTO-phenol red drops kit and 12+ gallons of plain 8% chlorine at Walmart.
    3. Add 4 gallons of plain bleach this evening for EACH 10,000 gallons of water in your pool. Test in the AM with OTO. Maintain a DARK yellow reading each AM. Test FC/CC levels every other day. Continue dosing like this, till the CC level is less 1 ppm or less.
    4. Test and report your CH (calcium hardness) readings.
    5. Tell us what all (make/product name) chemicals you have added this season.
    (. . . membership updated)
  1. trying to get my pool un milky
    By cdawg in forum --cleanup--
    Last Post: 06-26-2013, 09:52 AM
  2. Milky cloudy water - concrete dust? At a loss.
    By lady.k in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2013, 11:38 AM
  3. Replies: 3
    Last Post: 07-13-2011, 04:43 PM
  4. Milky Water and low PH
    By newbie2pools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-19-2008, 05:11 PM
  5. milky white water I suspect from cal hypo any thoughts
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 07:42 PM
