Alright so finally I am in the Ballpark! WOOHOO! Here are my numbers after adding a little more than 4lbs of Stabilizer:
Ph: 7 (Still too low, I'm going to add another box of Borax tonight)
FC: 7.5ppm (Yes still a little high, but thats OK... I will try to maintain a 6ppm based on the Best Guess Chlorine guide.
CC: 0
CYA: 50ppm
Water is perfectly clear, albeit cold at 70*.
Thanks for the help all. I do believe I will need to purchase another filter, because changing a filter takes a while to clean it properly and then cap and uncap the filter. (I currently do not have a shut off valve plumbed in between the inlet to the filter, and for some reason my shut off on the outgoing does not seem to work. When I drain off some of the pool water, I will probably just put new valves in.
