1. The booster and robot are overkill in my estimation. With the filter and pump you've got, you can manually vac the pool in 10 minutes.
2. The SuperFlo is way too much pump for most filters. You can NOT hook that pump to a tiny filter: it will either damage it OR force the dirt through the filter.
3. Best choice? Use the pump and filter, but get a motor rated timer. That pump will use WAY more electricity than an Intex pump.
