We purchased our home a year ago - it has an in ground 25,000 gallon pool with a sand filter and in ground cleaning system. We have been getting the pool ready to open - a few days ago we turned on the pump and within 20 seconds - water started leaking out of the inground cleaning system PVC pipes that are in the pool house. We turned the pump off and the leaking stopped. I want to include a few photos so someone can possibly help us - how do I do that lol. All pool stores around here are backed up until June and will not come out on an "emergency" call. So annoyed!! So basically the cleaning system in the pool house is 6 PVC pipes coming out of the cement in the pool house with a black top on it. The metal ring around the black top is busted. We have never used the system. Is there a way to bypass this and not use it - and not use the pipe with the possible leak. Just looking for some guesses since out local pool stores cant help for 3-4 weeks. Thanks!!
If the leak is in the pipe between the cleaning system and the pump in the pool house (under the concrete) - where would I poor the find a leak? Thank you again!
