Pool Overhaul
I would like to put a plan in place so that as my pool equipment either needs to be maintained or replace I can do so in a proper and economical manner.
I have the following configuration:
40,000 Gallon Rectangular Gunite Pool
Hayward Aquarite SWG with T-15 Cell
Hayward Ozonator
Hayward 525 SF Swim Clear Cartridge filter
Hayward TriStar 2.7 THP (2.0 FRHP/1.35 SF) Variable Speed Pump with Hayward VS Controller
2 Inch Plumbing
2 Fountains (only used when trying to cool pool)
2 Main Drains
2 Skimmers
8 Returns
Approximately 60 feet of head
No Heater
2 Hayward Color Logic LED Lights
Hayward Phantom Pressure Cleaner and Booster Pump
Pool's Open from April to October
Automatic Pool Cover
Since the pool's install, I have already replaced the pump seals on the Booster Pump twice. I now keep a spare motor on hand and swap it when it needs repair. My ColorLogic lights appear to be blown, I'll know for sure once my electrician installs Surge Protection which the PB never told me about. I would like to put in Pentair LED's because they are serviceable (but I do have Hayward Niche's (assuming that's what PB used). My Cleaner barely runs (plenty of pressure) but it just move like an old dog and its guts, hoses, and tail have all been replaced once since the pool was built in 2009. I've clean my cartridges 2 times a year (the bolt on cleaner is a pain to unwind)..My pool is clear and clean but I think it doesn't always sparkle and i think it could be better. I have replaced the Control Unit of my Pump once (expensive). Now my main pump motor is squealing like a stuck pig. The company that normally repairs my motor thinks I'm better off getting a new motor. lastly, I run my VSP on low 24 hours a day and only turn it on high occasionally to operate fountains to cool pool in hot summer.
I'm fearful of another controller being blown after i replace the Variable Speed Motor and I feel I can lower my maintenance cost by installing a 2 speed pump into my existing Wethead. Then I can get a switch (or motor with one built in) and toggle to high speed when needed.
What size replacement motor do I need? AM I better off replacing whole pump instead? Can I use the Pentair Lights in the Hayward Niches? If I switch to a Pentair Sand Filter, which size and do I need high flow rate or normal flow rate? Any suggestions on cleaner replacements? I open to other suggestions as well.
Thank you - this forum has been very helpfull.
40k gal 22x45 gunite rectangular pool; Hayward Phantom cleaner, Hayward cartridge filter, ozone system, SWCG. PF=3
