Thread: New to BBB method
    May 2014
    Default New to BBB method
    We are new to this method. We have an above ground pool, 27 foot round, 17,500 gallons, how do we get started?
    15k gal 27 round AG pool; PF=8
    BigDave's Avatar
    Default Re: New to BBB method
    #1) The most important thing is to get a good test kit. We recommend the Taylor K-2006 (or K-2006C - better value), you can't buy it in a store (that we've seen). If you log out then navigate to Forum->Testing and Adjusting Pool Water Chemistry->How to Get the Right Testkits for your Pool you'll find links. If you buy through the link, the pool forum will get some coin to keep the lights on.
    #2) Read, read all you on the pool forum and at poolsolutions.com. Get familiar with the best guess chart.
    Any questions, let us know.
  1. help with bbb method
    By clayboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-20-2012, 05:46 PM
  2. Why BBB Method?
    By brittmer in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-27-2007, 10:08 PM
  3. What is the BBB method exactly?
    By sdmanship in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-28-2006, 03:41 PM
  4. BBB Method
    By fritochiprt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-15-2006, 06:46 PM
  5. The B method.....
    By matt4x4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:34 PM
