Thread: Backwash water no longer green - pure white
    May 2014
    North Richland Hills, TX
    Default Backwash water no longer green - pure white
    I'm a DIY pool repair guy -- but only on my personal pool. I have an in-ground gunite pool with a DE filter. Having some issues, so thought I'd ask the knowledgebase!
    I recently took the cover off my pool (dark green), so I cleaned the filter first, then added DE to the skimmers and added algaecide and shock to the water, then fired it up. I backwashed about every 6-8 hours, and the first few times, the backwash water ran clear/dark green/clear -- as usual.
    But then yesterday, I backwashed again after 12 hours, and the backwash water ran clear/bright white/clear. That concerned me a bit, but recharged the filter with DE again. Then I started seeing DE shoot out of my jets. I immediately suspected a hole somewhere in my filter, so I took it out and inspected it. No holes ANYWHERE.
    So, I assumed I hadn't seated it correctly the first time, so I positioned the filter very carefully back in the tank and made sure the connection pipe was tight. I let it run for another 8 hours and backwashed again. And once again: clear/bright white/clear. And upon recharging the filter again, once again, DE shot from my jets.
    What am I doing wrong? I'm certain my filter is without holes. What should my next step be??
    Thanks!
    -Clint
    EDIT by Moderator: I combined both of your posts that were waiting in the moderation queue.
    Default Re: Backwash water no longer green - pure white
    . . . membership upgraded.
    White backwash from a DE filter, filtering water on a green pool, indicates the pool water is bypassing the filter.
    What pump / filter / valve do you have? If it's a multiport valve, have you opened the valve to make sure the spider gasket hasn't blown out?
  1. Swim Pure Salt Water System
    By Pshel82712 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2013, 09:08 PM
  2. green, cloudy water with white foam swirls
    By Rosie in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-21-2012, 09:16 PM
  3. water is not circulating / cannot backwash
    By coolpoolguy in forum Pool Equipment & Operations
    Last Post: 10-31-2010, 10:22 PM
  4. Pump still running but no longer moving water...
    By aylad in forum Pool Equipment & Operations
    Last Post: 08-27-2010, 02:35 PM
  5. backwash water goes into pool
    By Furbabyvet in forum Pool Equipment & Operations
    Last Post: 05-28-2010, 04:34 PM
