Results 1 to 3 of 3
Thread: Tri chlor shipping
    Apr 2014
    Idaho
    Default Tri chlor shipping
    Brand new to this forum, reading thru some of the trichlor in differences in brands, I found out last summer that the reason they individually wrap the pucks is for shipping. bulk (50) # buckets are considered hazardous individually wrapped they are not
    California
    Default Re: Tri chlor shipping
    You are correct that Trichlor is considered a hazardous material so would normally require special placarding and labeling and requires shipping papers which would increase shipping costs. To avoid this, most manufacturers package in a way to fall under the "limited quantity" exception which requires an inner packaging not to exceed 1 kilogram (2.2 pounds) of chemical and an outer packaging not to exceed gross weight of 30 kilograms (66 pounds) as per Title 49 §173.152(b)(1). So that is why the Trichlor tabs are individually wrapped.
    Another reason is to reduce fumes since there is liability from opening up a large bucket of Trichlor which can overcome someone standing over the bucket.
    15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
  1. Ben's Test Kit Shipping Time
    By rockpoolmike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-09-2006, 09:39 AM
  2. Any News on Shipping Times?
    By SherrySt in forum DPD-FAS based testing
    Last Post: 07-13-2006, 12:31 PM
  3. Question for Ben RE: PS234 kit shipping
    By prh129 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-18-2006, 06:15 PM
