Results 1 to 10 of 28
Thread: Overwhelmed
    Default Re: Overwhelmed
    Reaching down is not so critical. Avoiding surface water may matter, if the pool is dirty or has oil skim (from lotion, etc). What is critical is avoiding the return stream of water, if you have any sort of chlorinator or SWCG present.
    Apr 2014
    Mobie, AL
    Are there guidelines for what my readings should be, posted somewhere?
    Secondly, is there instructions for K-2006 somewhere? Correction, SIMPLIFIED instructions?
    AG, 7,000 Gallons, K-1000 and K-2006 Test Kits
  1. Intex Owner 15' x 48" overwhelmed
    By ATC_NH in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-13-2012, 04:49 PM
  2. Overwhelmed by all the pool chemistry
    By darylrue in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-31-2012, 02:05 PM
  3. New here. A bit overwhelmed.
    By Mwil3 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2010, 05:10 PM
  4. Overwhelmed with pool chemistry
    By muundance in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2006, 11:19 AM
