Results 1 to 10 of 35
Thread: New to the Forum
    Apr 2014
    South Carolina
    Default Re: New to the Forum
    Now we have an additional problem to report...
    I noticed a wet spot near the pool this morning, and measured the water level this evening. We had some light rain today, so I don't know an exact amount, however I do know the pool lost somewhere around 2.5 - 3 inches of water in the last 24 hours. My gut tells me that I managed to rip the liner while brushing the algae, however the water is too cloudy to see anything to verify. My calculations say I have lost around 1200 gallons.
    Does this sound like a possible (or probable) fix?
    I hate to keep throwing chemicals in the pool if the end result is a new liner anyways....
    20K gal 30ft AG pool; PF=6
    You might want to keep chucking bleach in in the evening, to avoid having it go green again. It DOES sound like it's the liner, but you might be able to patch it.
    Wait 24 hours and see if you lose another 2+"
    Apr 2014
    South Carolina
    Thank you PoolDoc.
    I just put another 4 gallons of bleach in, hoping that sooner or later the water will clear up so I can inspect for tears in the liner. Will report the water level tomorrow evening.
    Apr 2014
    South Carolina
    I can finally see the bottom of the pool, and am adding water so I can siphon vacuum out the dead algae. I also can see a small tear in the bottom seam where the wall transitions to the floor. The tear is in the area I would have expected, given the damp ground next to the pool.
    Do you have any recommendations on which patch kit to use? I have noticed two main types; one with the adhesive already on the patch, and one with cement separate from the patch. I was curious if one would provide longer lasting results over the other.
    Also, I currently have 0 CYA in the water, and would like to avoid getting the CYA levels too high. If I use a floater with tricolor tabs, I will constantly be adding CYA. Is the best way to avoid this simply increasing the CYA with store bought stabilizer, then testing and adding bleach as needed? I do not have a SWCG, so would I need to add bleach on a daily basis?
    You probably want to check out this thread:
    http://pool9.net/liner-patch/
    There are photos, links to the patch kits on Amazon, and to a leak-test video.
    IMO, the easiest way to add stabilizer is to use dichlor. If you buy a 24# pack of bagged dichlor at Sams Club, and use 15#, you'll have a CYA level of about 45. You can gradually use the rest to maintain stabilizer.
    Apr 2014
    South Carolina
    Algae is dead, liner is repaired, pool is filled, and the water is clear.
    I ran the tests a few minutes ago:
    FC - 19.5 PPM
    CC - 1.5 PPM
    PH - low (Acid Demand test - 6 drops to 7.4~7.6)
    TA - 20 ppm
    CH - 30 ppm
    CA - 45~50 ppm
    My thought was that TA would be the best starting point, is this correct?
  1. New to the forum
    By DanMan in forum Above-Ground Pool Construction & Repair
    Last Post: 07-22-2012, 10:42 PM
  2. New to Forum
    By jmajtyka in forum General Interest
    Last Post: 07-20-2012, 07:35 PM
  3. New to forum
    By KFollen in forum Above-Ground Pool Construction & Repair
    Last Post: 06-20-2012, 07:49 PM
  4. New to this forum
    By bssage in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-20-2012, 11:31 PM
