Results 1 to 10 of 20
Thread: Wanting to change wall mounted screen filter to a skimmer on Intex Ultra Frame pool.
    BigDave's Avatar
    Default Re: Wanting to change wall mounted screen filter to a skimmer on Intex Ultra Frame po
    When I had my intex inflateable ring pool, I had an Intex skimmer that mounted (sort-of) to the inflateable ring. It required alot of fiddling as the ring would expand during the day with the sun on it. I think that on a frame pool, it would work better. The following link looks like an updated version of what I had Intex Krystal Clear Wall-Mounted Pool Surface Skimmer. If you buy it through the link the PoolForum gets some coin to keep the lights on.
    I also had an above ground robotic cleaner that worked pretty well for cleaning the floor but didn't last very long. You could probably figure out a way to connect a hose to the skimmer's suction for vaccuuming.
    Apr 2014
    Texas
    I went to several pool supply companies looking for something to attach, but the only things they had were such small lines that without some serious reduction fittings they would never work.
    But again with this, the outflow would be severely restricted and that worries me as to how it could effect my sand filter pump.
    Long story short, I purchased a separate small pump, similar to what Big Dave mentioned and with a few adaptions have made something that will fit under the deck and run separately as just a skimmer by itself.
    Thank you guys for your ideas though.
    BigDave's Avatar
    I'd love to see a picture of your solution.
    Apr 2014
    Texas
    I'll post them soon. Just finished a good cleaning of the inside and will start filling it today.
    Thanks again.
    Apr 2014
    Texas
    Well, that didn't work as well as I would have liked.
    The small filter pump hoses must go over the side due to not having any existing holes and this creates a problem with the natural pressure of the water helping the pump.
    Long story short........ The basket collect a small amount of debris, but not nearly enough to warrant the costs.
    I can't believe Intex doesn't offer some type of product to skim their Ultraframe pools.
    But I'm nothing if not persistant and will figure something out if it kills me. LOL
    Thanks again for the help though.
    ps. Can someone explain why new members do not get access to the archives? I think it would save a lot of hassle for the moderators if we could look through previously answered questions, saving them much time re-answering the same thing.
    Intex Ultra 12x24
    Where are you not able to look? Have you tried using the Google search in the bottom of mine or Ben's signature blocks?
    If you are referring to the status of *Trial* members, the reason is that as many as 10% of new members on any given day are actually spammers. Some of those guys, if they get in, will post 100 or more times in a single hour, before one of us can catch it, creating situation that's very time consuming to resolve. Ironically, using the current gateway process, they usually don't even bother to post, since the New User section is not public, and not visible to Google.
    I've tried many things over the years to keep spammers out, but this current gateway process has been far and away the most effective.
  1. intex ultra frame 12x24x52 sand filter swcg system
    By rmills in forum Pool Equipment & Operations
    Last Post: 03-19-2014, 10:53 AM
  2. Intex 14x48 Ultra Frame Pool
    By Blmcmillian89 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-04-2013, 01:43 AM
  3. First time adding chemicals to 18x48 intex ultra frame pool..HELP!
    By babyblueiz77 in forum Intex-type Pool Setup & Operations
    Last Post: 07-10-2012, 10:15 PM
  4. Intex Ultra Frame Pool Hard Plumbing
    By labmom56 in forum Intex-type Pool Setup & Operations
    Last Post: 05-08-2012, 01:34 AM
  5. Who has an Intex Ultra Frame 24' pool?
    By jkoch in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2010, 11:54 PM
