Thread: High pH
    Aug 2012
    Texas
    Default Re: High pH
    So, to lower the pH, we have purchased muriatic acid. All the directions say add a 'little' at a time, but no ratio. So - 1/4 cup? And aerate to lower alkalinity also, or not?
    We're looking for the best solution. Last year, we poured massive amounts ($$$) of bleach in, then finally started adding dichlor, then clarifier and it finally cleared up. We did not cover the pool, so I would characterize it as a 'swamp'! We've used a Leaf Master to clear out leaves and major algae on top and bottom.
    Any suggestions are HIGHLY appreciated!
    18 round 6.7K gal AG vinyl pool; dichlor, bleach; jacuzzi sand filter; jacuzzi 1 speed pump; 7 hrs; ; HTH 6 way; utility water; summer: none; winter: none; none; PF:18
    Default Re: High pH
    more like, 1/8 gallon. Don't try to measure it -- doing so will create too many fumes. Instead, eyeball it. With a pH of 8+ and TA of 170, 1/8 gallons, give or take, will not be too much for a 7,000 gallon pool.
    Partially immerse the jug in the water, and then pour with the lip of the jug only a inch or so from the water. Doing minimizes the fumes. Only add acid when the pump is running, and wait 4 hours before retesting pH.
    Default Re: High pH
    It also minimizes the chance of acid splashing if you immerse the jug. Be sure to wear eye protection and keep the jug at arm's length.
    Alternatively, I fill a 5 gal bucket with pool water, and slowly pour the acid into that. I then pour THAT into the return stream, slowly.
    BTW, did you take a chlorine reading as Watermom suggested?
  1. High CYA, so keep FC high, so are my high PH readings, falsely reading high ?
    By tdurban in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-19-2013, 10:46 AM
  2. First Time Pool Owner Battling with Cloudy Water, High CC, High Ammonia!
    By yekalri in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2013, 06:48 PM
  3. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 04:47 PM
  4. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 10:52 PM
