Thread: Pool motor replacement for Hayward Tristar 2.5 HP 2speed
    Apr 2014
    Houston, Tx
    Default Pool motor replacement for Hayward Tristar 2.5 HP 2speed
    Hi all. Tried posing this question at another forum and I just got more confused. I'm looking to replace the motor on the Hayward pump. The old motor was made by Emerson which I now understand to be US Motors. I tried searching for the closest match which I think I found on this website. The only spec that seems different is the lower amp. Does that make it incompatible? Or any other downside for going this route? Looks like I can't post a picture yet of the label on the old motor. Anyway I could email it to one of the mods? If not here are the specs listed on the label:
    2.5HP 1.1SF. 56 Y frame SF amps 13.4-12.0/3.8-4.1
    Model R63CXDRS-250
    SP3220Z2MER
    RPM 3450-1725
    http://thespaworks.com/parts/general...-y-frame-motor
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pool motor replacement for Hayward Tristar 2.5 HP 2speed
    Some of us post on both forums.
    Please read my last post.
    Mark
    PS. "I be a Lee" too, by ancestry if not by last name. My great-grandmother was Helen Lee, and I'm told, was Robert E's great-niece. I'll have to check that at Easter dinner today: my sister is the one who gotten the genealogy bug.
  1. Northstar pump motor replacement
    By masksav in forum In-Ground Pool Construction and Repair
    Last Post: 04-01-2012, 05:13 PM
  2. Pool motor replacement
    By tippywanknobi in forum In-Ground Pool Construction and Repair
    Last Post: 01-16-2012, 05:08 PM
  3. Bearing Replacement 1hp AO Smith Motor
    By Spurgeon in forum Pool Equipment & Operations
    Last Post: 05-15-2010, 01:18 AM
  4. Which Replacement Pump Motor???
    By vgg659 in forum Pool Equipment & Operations
    Last Post: 07-07-2009, 04:21 PM
  5. AO Smith replacement motor suddenly noisy
    By rbonin in forum Pool Equipment & Operations
    Last Post: 05-31-2009, 12:00 PM
