Re: 20k gal pool in Sol Cal. .....needs to be drained.
"Don't put liquid chlorine in with the pucks"
I have a floater, so if the pucks go anywhere, it's in the floater.
If I put liq. chlorine in the pool. I pour it in at the deepest part of the pool slowly with the pool pump on for at least an hour, same with muratic acid.
I guess I don't understand how you could put liq. chlorine in with the pucks? Is this with an in line puck holder?
plaster 20k gal kidney shaped swimming pool with spa Hayward Vac, Nautilus DE filter, Raypak RP2100 gas heater.
