Results 1 to 10 of 13
Thread: Testing & treating pool fill water
    Apr 2014
    Default Re: Testing & treating pool fill water
    Alright, the new liner is half-installed and the pool is filling. They will come complete the installation tomorrow and I am guessing it will take a couple more days to fill completely.
    Let me make sure I understand:
    Until the pool is full, nothing but the pink stuff and some polyquat.
    Then, when the pump is running, first lower pH to 7.0
    Second, raise TA to 80 ppm
    and THEN start chlorinating slowly (2ppm/day). Since I'm using Dichlor, I don't need to add additional stabilizer.
    A couple of questions:
    What should my goal FC be? 4ppm? And CC < .5ppm?
    Should I check CYA each day while I'm chlorinating to make sure I don't get it too high?
    Will the pink stuff keep working all summer?
    Thank you again for all your help! The pool looks so new and shiny, I want to keep it that way.
    In-ground vinyl pool ~23,000 gal. Sand filter with zeosand.
    Sorry I overlooked this:
    Target FC is determined by CYA level => see http://pool9.net/cl-cya/ (Best Guess Chart)
    Do NOT check CYA daily; you'll consume your reagents. It doesn't change that rapidly. Here's the CYA refill if you need it: Taylor R-0013-E @ Amazon
