Results 1 to 10 of 41
Thread: What to do first? CYA > 200 ppm
    Default Re: What to do first?
    Good.
    The fact that you have a DE filter with a slide valve means vacuuming to waste would be difficult -- you'd have to add some valves. That makes it impractical to use the whole pool lime-softening technique, at least for now. But there may be some intermediate steps you can follow.
    One point I should emphasize is that the so-called BBB method I originated (I came up with the method, not the name) is not literally bleach / borax / baking soda: rather those products are more symbolic of the approach of using the easiest, cheapest and best way to care for your pool. And one of the fundamental points of the BBB method is that you have a POOL, not a 'set of test numbers'. So, we don't worry too much about numbers, when they aren't causing a problem.
    Unlike pool stores, who want to sell chemicals, we try to avoid fixing what's not broken!
    In your case, if you have no tile-line scale . . . you are NOT having a calcium problem, even if your level IS 560 ppm. So, let's get more accurate info on your numbers, raise the chlorine, and then re-assess.
    Aug 2013
    S. California
    Good.
    Okay, I just got done dumping 442 ounces of 6% bleach into the water. How long do I wait before I do a chlorine test? The pump is running at 3110 rpm right now.
    Oh, I do have a scale ring. Plus, I think I have scale buildup on the bottom too. I'll see if I can get some pictures of the bottom.
    21.5k gal IG plaster, free form, PAC-FAB Nautilus NFS-60 DE filter; Pentair IntelliFlo pump; LAARS Series One gas heater. Hayward Ultra pool cleaner. Taylor K-2006 test kit.
    2 hours should be plenty, to wait. It sort of depends how your pool's circulation system is set up, but regardless, 2 hours should be enough.
    Pictures of both tile & bottom, if you can, please. Post them, or links to them, using Webshots, Flickr, Google Drive, etc, or email them to poolforum@gmail.com. To take the pool into a scale-removing state will be a bit tricky, but I've thought of a way that may work.
    Also, take pictures of your equipment. PacFab changed their name to Pentair a long time ago; how much like your filter is this one: http://www.pentairpool.com/pool-pro/...filters-61.htm ?
    Aug 2013
    S. California
    Aug 2013
    S. California
    At 13:45 pm my time, the FC level is now 5.5.
    Adding more bleach. And testing CYA.
    Aug 2013
    S. California
    At 14:30 the CYA = 240. I mixed 7ml of pool water with 14 ml of tap water. Took 7ml of that for the test. Reading was 80. 80 x 3 = 240.
    Also, added another 128 oz of 10% bleach.
    Aug 2013
    S. California
    At 16:15 pm, the FC is now 10. Yeah!
    What's next?
