Ben makes good points, all of which you need to follow.
This is not your problem to solve, it's the builder's. If it's truly 2"/day, I wouldn't accept patchwork repair.
About the algae under the waterfall, I see this more often than you'd expect under natural rock waterfalls. My assumption is that the water is pulling a contaminant from the rocks or from between the rocks and depositing whatever's necessary to get the algae going. We did a job earlier this year with the same issue. They'd let the algae sit long enough that the plaster was seriously pitted and rough in that exact area. Everywhere else was pristine. Rather than replaster an entire pool over 10% that was bad, we were able to grind it smooth with a diamond wheel. All that said, I don't know what the fix would be to prevent it from happening again, other than to stop using the waterfall (route my clients took).
Another thing, leaks are sometimes not in the obvious location. That crack is suspicious, but it very well could be a return pipe that some worker forgot to glue (happens).
Good luck & keep us up to date. Share some pictures if you would please.
