Thanks again, guys. Here are some comments/answers in the order they appear above:
CHEM_GEEK: I add chlorine at late dusk (so I can still see). My pump runs 24/7 from Spring open to Fall close. I will check 30 minutes after adding my next dose, but in the past, when I measure in the morning, my test strips are >20. The stronger the dose of chlorine, the longer it takes to get back to zero but it eventually does within a few days. I don't know what you mean by "eliminate the possibility it going away from sunlight due to lack of CYA" but those are my results.
I checked with the pool store and they DID use a lot of dichlor last year, more than I thought. I used only one bottle of Super Soluble but THEY added (at their expense) a bunch of Super Soluble last year. Because it was a freebie, there is no record of the quantity but I remember it was at least 50 lbs. and could have been as much as 70. Since last year there has been no addition of products containing dichlor.
I added an avator of my pool as it is today. Not that it helps as the picture is so small. I took the picture from my second floor and from there I can still see the main drain. My pool is around 30,000 gallons. The Bioguard rep suggested replacing 2 feet of water to get my CYA down to under 25 and then retest the chlorine demand which is when I began this thread in the first place. I never did the draining, but I did add about an inch and a half of water since then.
I will try the bucket test after the party tomorrow. Then I will know how much chlorine to add. If this assumption is incorrect, please let me know.
POOLDOC: Last night I took a pool sample in to the pool store to test pH. (I am not a good judge of that color spectrum). They said it was at 7.8. I added between 1/5-1/4 gallon of muriatic acid.
I ran an OTO test today. Light, light yellow. The color did NOT change at all after one minute.
I have been using bromine since it was built in 2005.
I ran my own ammonia test today. It was very yellow and so no ammonia.
Thanks for the link about contact dermatitis. It was very interesting and explains why my nephew gets a rash in my pool! He now takes a shower after each swim which takes care of the problem.
