Re: Can anyone tell me if you can recalibrate a MS10 Salt Generator?
Hayward makes the Mineral Springs unit, so it's the same as the Aquarite/Goldline salt system.
Is the unit reading High CELL? or High SALT? I'm not familiar with the High Cell display, but a high salt usually indicates high conductivity in the water, caused by a new cell, high salt, or warm water. If it's none of these, then there may be a problem with the power supply. If it's high salt, you cannot calibrate it, but I believe it takes a day or two for the salt "Average" to level out once salt has been added or a cell has been replaced. Since you posted this a few days ago, it should have leveled out. So if it's still showing high salt, there are other possibilities.
It's possible that depending on the software version (1.5 or newer), you may have to "set" the cell type:
"t-3" = T-CELL-3, GLX-CELL-3-W
"t-5" = GLX-CELL-5, GLX-CELL-5-W
"t-9 = T-CELL-9, GLX-CELL-9-W
"t-15" = T-CELL-15, GLX-CELL-15-W
1. Slide the Main Switch to the "Auto" position.
2. Push the Diagnostic button repeatedly until "t-xx" appears on the display ("t-15" is the factory default). If the desired cell type is displayed skip to step 4.
3. To change to a different cell type, slide the Main Switch from "Auto" to "Super Chlorinate" and back to "Auto". Repeat this process until the desired cell type is displayed.
4. Push the Diagnostic button to exit
This would adjust the high salt levels to the actual cell installed, as the salt level is based on the amps and volts going to the cell.
Hope this helps,
Sean Assam
e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
