Thread: Bought foreclosure with in-ground green "swamp" pool
Threaded View
    Jul 2013
    Maine
    Default Bought foreclosure with in-ground green "swamp" pool
    Just saying hello and getting my required first post out of the way. I have made significant progress on clearing up the 21,000 in-ground swamp that was in my new home's back yard, but now it's been a cloudy blue for a couple weeks. I figure it's the dead algae, and the sand filter wont filter it. Still can't see bottom, so I vacuum blindly and getting less and less debris out of deep end each time. Used pool filter cleaner (degreaser) last night and backwashed it out this morning so maybe that will help... Also brushed the walls again.
    My "pool progress":
    Looking for any other tips to clear up cloudiness. I do see bubbles from my jets every so often, so I'm guessing that's probably not helping. Can't determine where air leak might be though.
    Filter is Hayward S200 Sand filter. I'm guessing it was installed back in mid to late 90s at least. No idea when sand was last changed out, so that might be my next plan of action.
    I've also just read where you can add some DE to a Sand filter to help it work better. Anyone want to verify that? If so, how much? And to where- the skimmer? I haven't been able to get into my filter without taking out all the hex bolts at the mid-section, but I've just ordered the special Hayward Dome wrench on Amazon that allows the top dome to be taken off... Can sand be changed out with just the dome off (using a shop vac to remove old sand), or should I remove all the hex bolts at the mid section?
    Thanks,
    Aaron
