Thread: Run downspout to pool to use roof run off ?
    BigDave's Avatar
    Default Re: Run downspout to pool to use roof run off ?
    Might be OK if your gutters are clean (mine always have some sort of tree droppings in them). If you have an asphalt shingle roof, you may want to rig some way to catch the little rocks that coma off the roof.
    I'm just not sure why you want to do this. My pool overfills when it rains and only needs water when there's no rain.
    Jun 2013
    Atlanta Georgia
    In the hot sunny summer I get about an inch of water loss a week from evaporation. I don't bother to refill the pool with a hose until it is at least an inch below the drain. If it is an inch below the drain, in a long heavy rain my pool will over fill, but a lighter or shorter rain might only fill it half an inch. I thought if I ran something from the down spout it might be better.
    BigDave's Avatar
    Solar blankets help with evaporation, but maybe your pool's too hot already?
    You may want to leak check your pool. I'm only 100 miles north of you -- and I'm pretty sure you've basically had the same rain we have. A loss of 1" per day, given the weather this summer is possible but not very likely.
    Regardless, you want to make sure your chlorine level is pretty high, after you wash off your roof into your pool.
    http://www.poolforum.com/pf2/showthr...he-bucket-test
    May 2011
    Southeast Massachusetts
    I think it was PoolDoc that mentioned bird feces in a somewhat related thread. Anything like that on your roof will be present in the water going into your pool. Enough chlorine will mitigate that I suppose but still. I would rig up some mesh or screening at the bottom to catch any debris coming down as well.
    15,000 Gallon AG -24' round -- Vinyl Liner -- 1 HP Hayward Power Flow LX -- Sand Filter -- PF=5.5
