Hello all. I recently took a 25k gallon pool under my wing. Things have been pleasant so far, no algae, water stays clear, no CC's that I can detect with Taylor 1005 kit. But, my CYA is at 60. I was doing a little research, which brought me here and to the best guess chart, which tells me I should be keeping my CL around 4-8 instead of the 1-2 where I've been keeping it. I'm using stabilized tablets, and now I understand that continued use will drive my CYA higher. However, I really enjoy the convenience of loading the feeder once a week.
So here's my question, if I switch to bleach, how often will I need to add it? I know this can vary, but I'm wondering what addition schedule people are typically following? The other option I have is to change enough water to keep my CYA down and keep using the tabs. Trying to figure the most cost effective/time effective approach.
Here are my current parameters (I know, should have gotten the K2006, it's on the shopping list):
FC / TC - 2
CYA - 60
ALK - 85 (adding about 3 pounds bicarb/week)
pH - 7.5
CH - 400 (I haven't added any, started out with this number)
It's a 25k gallon vinyl liner pool. Pump runs 24/7, Hayward sand filter and Hayward chlorinator currently using trichlor tabs.
I welcome any and all suggestions, thanks!!
