Ok so here is what's going on we recently bought an above ground pool 15 feet by 42 inches so I have it estimated at around 3800 gallons . I filled the pool with well water and when it was filled up water looked dirty and green so I decided to go and get some of the 6 way test strips from Walmart to test the water . I know those are not that accurate but I'm thinkin purchasing a kit from here in the future so for the results i got these readings
TH- 1000
Fc-0
Ph-8.4
TA-240
Cya-30-50
Now from what I have been reading is to try and balance my ta first so I have been adding muratic acid for the past couple days . I have only been adding 3/4 of a cup a day which is the max I can put according to the label . Now the water is getting clearer but it seems I have too much iron in the water because filter comes out with a copper color residue and when I scrub the bottom of the pool I can see some of that same residue moving . Also my walls feel slimy what's could that be . Now for my other question should I keep adding muratic acid to try an lower my ta or add chlorine ? Numbers haven't moved one bit even with the acid . Thanks in advance for any help
