Re: Hayward pump cutting out several times a day - is this normal?
I'm baaaaaaaaaaack!
I started this thread last year and described several symptoms. I can now say this: if in doubt as to whether you have bad motor bearings on a Hayward pump, wait a year. It's now quite obvious: my bearings are toast. I had to really work to (manually) get the impeller to rotate and the bearings sound awful! And the motor is running hot and all the rest.
So, given my motor: A.O. Smith UST1102 (Model No. C48K2N117A9; 1hp; 3450rpm), can anyone say FOR SURE what bearings to order?
I have heard "6203" (both ends), but when I went up on Amazon (for example), I see various 6203 flavors:
6203ZZ, 6203-2RS, 6203-2NSE, 6203RS, 62032NSENR, S6203-2RS, 6203, etc.
I suspect these may all be the same thing (size). Is the main thing the dimension spec: I.D. x O.D. x W (17mm X 40mm X 12mm) ??
30K IG pool/ Hayward Super pump SP2607X10 wired 220V; timer from 8am-8pm; Hayward S-240 sand filter; new multiport valve; normal psi 24psi.
