Results 1 to 9 of 9
Thread: Considering UV for a new outdoor pool.
    Jun 2013
    Ontario Canada
    Default Re: New and Partially Regretting Buying a House with a Pool
    Thanks for the response Big Dave.
    I got interested in the UV process because we use one at our cottage to prep lake-drawn drinking water after a sand/rust and then an activated charcoal filter. The water becomes potable after the process (had it tested), so I was interested in thoughts on its use in a pool. It seems to limit the need for chlorine from what I have seen so far.
    Salt water is on my radar too, although my understanding of the process is limited and it seems to be a bit of a misnomer, as what it seems to do is create chlorine.
    I am definitely going to implement a BBB system for the time being as the price tag on SWCG and UV is too high for me right now (and heck, the price of bleach is RIGHT!)
    BigDave's Avatar
    Sanitizing potable water is different from sanitizing pool water. UV systems can only kill pathogens that are passing through the UV system at the time, they don't kill anything in the pool. Chlorine, on the other hand, is in the pool ready to kill pathogens when they are introduced. No one is completely clean, pool sanitizer must kill the bacteria that washes away from the far end of a swimmer's GI tract before it gets to the near end. UV systems can never do this.
    UV systems have a place but not in outdoor pools. That said you can find someone willing to sell these systems with claims along the lines of "reduce the use of Chlorine" and "lets you run lower, safer, chlorine levels". The first reason is just plain bunk, UV destroys chlorine so it's just not possible that it could reduce the consumption. The second reason is worse than bunk, it implies (or supports the notion) that chlorine is "bad", it is not. It also encourages a dangerous reduction in sanitizer level that may leave swimmers very sick.
    Please reconsider the notion of using a UV system for an outdoor pool. At best, it lightens your wallet; the downside can be much worse.
    Jun 2013
    Ontario Canada
    Exactly the discussion I came here looking for, thanks Dave!
    BigDave's Avatar
    Good, you'll need the money you save on the UV system for the inflated Taylor kit prices north of The States.
  1. Private Outdoor Pool Surface Cleaning - Questionnaire
    By spnshlaura in forum --cleanup--
    Last Post: 10-30-2012, 08:22 AM
  2. Outdoor sound system for my pool
    By TarheelFan in forum General Interest
    Last Post: 05-03-2012, 12:06 PM
  3. Outdoor Bleach???
    By quenterry0 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-15-2007, 08:35 AM
  4. Outdoor shower
    By DONNIE in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 06:06 PM
  5. Indoor/Outdoor Carpeting around pool?
    By NWMNMom in forum General Interest
    Last Post: 06-18-2006, 11:18 AM
