Thread: Higher chlorine use this year with BBB method
    Jun 2013
    Tennessee
    Default Higher chlorine use this year with BBB method
    using the BBB method and Im using about 3-4 quarts of bleach a day is this ok seems like I was using less last year when my CYA was high 7-10. this year beginng satr up Cya are 10-20 and ph is fine. But using alot of bleach ????
    thanks and sorry for you hacker troubles. John.
    Default Re: Higher chlorine use this year with BBB method
    You'll use less chlorine, at higher CYA levels, even with higher chlorine levels.
    Raise your CYA to at least 40 ppm. Read the Best Guess page linked in my signature.
    Jun 2013
    Tennessee
    Thanks Doc
    you're welcome.
  1. Replies: 3
    Last Post: 05-21-2013, 03:16 PM
  2. Best Method for Pool and Spa Sanitation for Chlorine Allergy
    By LarryFlorida in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-19-2013, 04:25 PM
  3. higher pressure noted this year and dont know why
    By smgchandler in forum In-Ground Pool Construction and Repair
    Last Post: 06-09-2008, 12:52 PM
  4. Higher chlorine loss than last year
    By dancu in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-02-2007, 11:52 AM
  5. Chlorine Higher than 15ppm
    By CUTURHAIR in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2006, 02:52 PM
