Thread: Hayward Heat Pro repeated coil failures
Threaded View
    Aug 2011
    Default Hayward Heat Pro repeated coil failures
    When we installed our 5000 gallon in ground pool about ten or so years ago we installed a Hayward HP21002 heat pump to the tune of about $3500...
    It worked just fine however after about five years the coil eroded away and disintegrated so we replaced it at the cost of aprox. $3200...
    Well now about another 5 years later it has done the same thing and I do not want to spend that kind of money again, heck...that's $6000-$7000 for ten years...that's way too much...
    This time I did a little research and found that I can buy just the coil for $600 - $700...
    Problem is that I don't know where which online vendors are good and which are not... I would post some pix here but apparently I do not have permission to do that probably because I am a newbie here...
    Is that the life expectancy of these coils...? Doesn't seem very long to me for the kind of money they cost...
    Any info and/or advise would be very appreciated...
  1. Replies: 5
    Last Post: 06-14-2012, 10:56 PM
  2. Hayward HP2100TCO replacement heat pump
    By dixie600mhz in forum Pool Equipment & Operations
    Last Post: 10-06-2011, 10:20 AM
  3. Who knows their Hayward/EUS heat pumps???
    By dawndenise in forum Pool Equipment & Operations
    Last Post: 09-09-2009, 11:10 AM
  4. Hayward Heat Pump - What type?
    By Calicat2u in forum Pool Equipment & Operations
    Last Post: 06-24-2006, 11:27 PM
