Thread: Aqua Genie pool skimmer system
    Jun 2013
    Sask. , Canada
    Default Aqua Genie pool skimmer system
    Building a new 16x32 inground pool, standard 8ft deep end. Was told to put in 2 aqua genie skimmers and no main drains. Good idea or not?? If yes, should I put them each 1/3 of the length from each end??
    Default Re: Aqua Genies!!
    Is this what you are talking about?
    https://www.hydrapools.com/aquagenie/order
    If it is, I'll make the following observations:
    1. I have zero personal experience with them.
    2. The skimmers shown are complex devices. In my experience, pool devices that complex *usually* don't work as advertised, but when they do (like the Polaris 360 pool vacuum) they have undergone years of development and improvement.
    3. Main drains are simple and do work.
    If you want an easy, fairly reliable cleaning system, I'd recommend you look into a Polaris 360 system. These require a built in line, so now is the time to look at it.
    Polaris 360
    Polaris 360 manual (read before buying!)
    Zodiac F1 Polaris Vac-Sweep 360 Head and Hose Pressure Side Pool Cleaner @ Amazon (read reviews!)
  1. Correcting a No flow problem on Aqua rite salt water system.
    By Knipper in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2011, 12:53 PM
  2. Closing Question - Aqua Cover(skimmer)
    By jrv331 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-12-2006, 07:26 PM
  3. Anyone tried that pool genie stuff ??
    By hancop in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-24-2006, 04:31 PM
  4. Pool Genie?
    By zephans in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-26-2006, 06:11 PM
