Thread: pH adjusting
    Jun 2013
    Near sunny Buffalo NY
    Default pH adjusting
    To adjust the pH levels using muriatic acid makes me a little nervous. Are there any negatives to using Walmart's HTH pH Plus:
    •Raises pH levels
    •For use with swimming pools
    •5-lb canister
    or
    HTH pH Minus:
    •Lowers pH levels
    •7-lb canister
    Default Re: pH adjusting
    "pH plus" is usually sodium bisulfate -- or half-reduced sulfuric acid. It's also sometimes named "sodium hydrogen sulfate" (but NOT: sodium hydrosulfite, which is different!)
    In a vinyl pool, the only down side to this product is increased cost. In a concrete pool, sulfate build-up can damage concrete.
    Jun 2013
    So to raise the pH level borax would be a better choice?
    Yes, to raise pH, use 20 Mule Team Borax (laundry aisle at Walmart).
    Jun 2013
    Sometimes I can gather too much information and confuse myself. I just printed The BBB Method and I think I'll be OK. Thank you.
  1. help adjusting
    By poolhelp101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2013, 01:39 AM
  2. help adjusting
    Last Post: 06-17-2012, 08:27 PM
  3. adjusting alk, PH, and cl
    By spongebob55 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-23-2007, 07:02 PM
  4. help with adjusting please
    By poolhelp101 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2007, 10:03 PM
  5. adjusting low pH
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2006, 02:49 PM
