Results 1 to 10 of 12
Thread: Pressure Problem
    Jun 2013
    Connecticut
    Default Pressure Problem
    New here - hoping for some help.
    Have a 20K gallon in ground pool just opened. Pressure last year at sand filter was about 12 to 15 PSI. It is now only 3, barely able to vacuum. Tried a drain king to clean out skimmer line to no avail. A little air in pump basket area, not much. Pump impeller looks clean.
    Here is the kicker - I seem to get more flow at the skimmer when in waste mode than in filter. Don't get a pressure reading unfortunately when in waste or recirc mode. Any ideas would be much appreciated.
    Default Re: Pressure Problem
    membership upgraded.
    Jun 2013
    Connecticut
    Yes, backwashed several times. When running in filter mode, the pressure is only 2 to 3 PSI. If the filter was clogged I would expect the pressure to be higher.
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    you put drain king in your skimmer . acid probably not goodfor it . if good pressure in waste mode still works ,so look for the blockage inline . does it dump alot of water during backwash good flo?
    Jun 2013
    Connecticut
    Had a pool company here yesterday. They blew out all lines with a blower, inspected multi valve, still no idea. Get good flow on backwash or waste, very low in filter or recirc mode.
  1. problem with return water pressure
    By meeka in forum Pool Equipment & Operations
    Last Post: 06-13-2013, 10:26 AM
  2. Old SP-711 pressure problem
    By shadowman in forum Pool Equipment & Operations
    Last Post: 07-17-2011, 09:28 AM
  3. low pressure problem
    By wratran in forum Pool Equipment & Operations
    Last Post: 05-19-2010, 05:26 PM
