Thread: Backwash, rinse or waste cycles loose pressure on hayward sand filter
    Jun 2013
    Virginia
    Default Backwash, rinse or waste cycles loose pressure on hayward sand filter
    I have no pressure when backwashing, waste or rinse.
    Default Re: Backwash, rinse or waste cycles loose pressure on hayward sand filter
    Are you sure your gauge is working? Does it go to zero when the pump is off? What is the pressure when it is set to filter?
    Welcome to the Pool Forum, by the way!
    Jun 2013
    Virginia
    Pressure on gauge is 11 for filter mode.
    membership upgraded.
    We seem to have different sets of common problems each year. This year, problems with low pressure on various multiport valve positions seem to be common. Unfortunately, there are many possible causes, and we can only do a little to help -- most of the work, checking for possible problems, has to be done by YOU.
    If you'd like us to help, we'll need pump, filter, and multiport valve make and model; pressure readings with pump off, pump on and filter in recirculate, pump on and filter in filter; and ideally, pictures using Picasa, Webshots, Flickr, etc. to post.
    Also, you'll need to say what you mean by having "no pressure" when you are in these positions. Pool owners often confuse pressure and flow. Do you mean that, when you backwash, your pressure gauge shows a low pressure? Or do you mean that when you backwash, the pressure gauge isn't that low, but that there's very little flow out of the discharge pipe?
    If you mean the second, look for a valve or restriction on the discharge line.
    Good luck!
  1. Backwash, rinse, filter blows junk back in pool, possible waste line issue
    By Cankoo's pool in forum Pool Equipment & Operations
    Last Post: 04-27-2012, 03:37 PM
  2. when to backwash sand filter
    By Kateyru in forum Pool Equipment & Operations
    Last Post: 04-19-2012, 10:16 PM
  3. short sand filter cycles
    By jeffmarc in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2006, 09:34 AM
  4. Hayward Sand Filter 240- pressure?
    By JJParrish in forum Pool Equipment & Operations
    Last Post: 07-13-2006, 02:32 PM
