Results 1 to 10 of 17
Thread: Intex filtration problems
    BigDave's Avatar
    Default Re: Required post
    What kind of vac do you have?
    Jun 2013
    Kansas
    The one that came with it. It attaches to my garden hose and has a catch bag. It is only good for larger debris. I would assume I need one that attaches to the pumps inlet so that it filters it through the system. The ones I have researched attach to a skimmer that isn't a factory option for this pool. I'm lookin into adding a universal bigmouth skimmer.
    BigDave's Avatar
    I used to have just such a venturi vac. I managed to convince it to catch smaller debris by adding a section of nylon stocking. I cut 12-15 inches of the foot of a stocking and lined the debris bag. I matched the open end of the nylon with the open end of the bag and tied them both with the debris bag's string. This caught much finer stuff but still had the problem of filling the pool. Eventually I purchased an above ground pool robot that made the venturi vac obsolete.
    Pentair and Jandy make fine mesh bags -- usually referred to as sand and silt bats -- for their products. Usually, these bags are interchangleable. Please note that they will NOT capture algae and pollen dust.
    Here are links to those products on Amazon -- the second link is a cheaper no-name version, probably Chinese. It may work fine, but it may also be junk. The Pentair bag should be fine, so long as you understand the limitations mentioned above.
    Pentair R211286 Sand/Silt Bag Replacement Leaf Eater 185 Pool and Spa Safety Equipment
    PoolStyle PS454 Fine Mesh Leaf Eater Bag
    Jul 2012
    Mexico, Missouri
    Because I'm a cheap son-of-a-gun, and can't see buying a vacuum head for a 15' pool, I bought a 24' long pool vacuum hose and use it without an end on it.
    I did buy a universal pool hose adapter so I could use the
    Surface Intex Skimmer Small Strainer Hose B Adaptor
    to clean the dirt off the bottom of my pool.
    I brush the pool to stir up the fine particles, then a couple of hours later I vacuum what has settled back into the wrinkles in my liner.
    Hope this helps!
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jun 2013
    Kansas
    Thanks for all the help. The wife picked up a test kit from Walmart but it only had two types of chemical testers in it. We will have to go back to the pool store and get the full kit so I can post up my numbers.
    Quote Originally Posted by teamwir View Post
    Don't!
    We have NEVER heard of ANY pool store selling the kit you need -- a drops based kit, testing pH, Alk, Calc, CYA *and* FAS-DPD chlorine. In particular, the FAS-DPD chlorine test + the drops based CYA test are essential for managing your pool successfully.
    Order the K2006. You don't have to buy using the Amazon link below -- there are other online sources -- but use it to look at what you need. If it's not a Taylor K2006, it's not what you need.
  1. pool filtration
    By ladypoolfool in forum Pool Equipment & Operations
    Last Post: 06-14-2013, 03:43 PM
  2. Calciium problems in an Intex pool
    By justlane4 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-08-2013, 01:32 PM
  3. Filtration problems / pump size
    By thedubb in forum Pool Equipment & Operations
    Last Post: 05-29-2013, 06:33 PM
  4. Intex AG Blow up ring problems
    By edlentz in forum Above-Ground Pool Construction & Repair
    Last Post: 09-29-2012, 11:39 AM
  5. Contacting Intex Corp for parts or problems.
    By PoolDoc in forum Intex-type Pool Setup & Operations
    Last Post: 07-13-2012, 10:05 AM
