Thread: CYA test
    Jul 2011
    Wantagh
    Default CYA test
    Just put in new liner so total refill(26,000 gal) added bleach until it was in range next I added 4 CHLOR-GUARD pucks (1 per 5000 gal) still some of 1 left. I know I need to add more plus we just had so much rain my pool overflowed and then I had to pump some water out but did the test for CYA anyway. The water didn't cloud up at all,I'm using the taylor with 3rd season regents(always kept in basement). What do you think bad regents/not enough pucks to show CYA yet or both? Thanks
    inground rectangular pool 16' x 36' 8' deep end 26,000 gallons black vinyl liner
    Default Re: CYA test
    Assuming you are using the Taylor R0013 reagent system, no cloudiness = no CYA. So far as I know, the R0013 does not deteriorate.
    However, if your pool water is clear, it's easy to verify this: just add a couple of gallons of bleach early AM on what is to be a fully sunny day. Test an hour later, and again at the day's end. If there is CYA, there will still be quite a bit of chlorine left. If there is no CYA, the chlorine will have almost completely disappeared.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
