Results 1 to 10 of 57
Thread: Strange test results -- very high combined chlorine (CC)
    May 2013
    Northwest Indiana
    Default Re: Strange test results
    I reposted the motor question in the pool equipment section with more details... I did find a model # on the motor (sp2600zlc) but after searching the web, i still cannot determine the hp. If that's still not enough info, i will post photos.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    Hayward motors will have a SP number, but for example, a SP2610x15 is a 1HP pump that gets uprated as a 1.5HP pump.
  1. Combined Chlorine High
    By StratDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2012, 08:30 AM
  2. Strange test results, help!!
    By lisak in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-20-2010, 03:59 PM
  3. Initial test results...green ring, combined chlorine...HELP!!!
    By Sheri in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2010, 11:51 AM
  4. Super high combined chlorine
    By themaccs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2010, 02:45 PM
  5. High combined chlorine level won't budge
    By Carolina in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-13-2006, 08:54 PM
